Hello Everyone,
Glad to tell you that 24inch & 26inch 205 35H V1 e-bike hub motor is available now.
Here are some pictures for reference:
1). 24*2.125inch 205 35H V1 e-bike hub motor:
2). 26*2.125inch 205 35H V1 e-bike hub motor:
Meanwhile, we have update the package for all of our Front and Rear Moped Wheel Rim Assembly Set.
And the new package is more reliable with less weight, save money for internation delivery.
For instance, 1. Rear wheel set with new package
2. Front wheel set with new package
Furthermore, we can provide 2 kits Combo for this 205 35H V1 e-bike hub motor
Combo 1:
205 35H V1 Kits, With Kelly Controller
Combo 2:
205 35H V1 Kits, With Yuyangking Controller
Here are spec for each kit:
1). Controller:
a. Kls7212s:
sine wave controller, programmable, with regen function
Motor Current Limit, 20 seconds: 120A;
Motor Current Limit, continuous: 60A
Battery voltage: 24V-72V rated, max. 90V
Thermic Probe: KTY83-122
Including one controller + USB convertor cable + matched plug
Controller Size: 108mm*78mm*41mm
Waterproof IP54
b. Kls4812s:
Battery voltage: 24V-48V rated, max. 60V
Waterproof IP54
c. QSYK7250J
Power supply:48V-72V, Limitied current: 50A , Max phase current: 150A
Product Size: 280mmx117mmx60mm
Net Weight: 1.16kg
Testing way: Hall sensor
Including: 1pc controller + 1pc Function harness
P.S.: For Software & Manual, please contact with us freely.
It support Bluetooth Function with Bluetooth Adapter.
2). QS Thumb throttle:
Color:black
Wire length: 50cm
3). QS Freewheel:
MF-TZ21 Cassette 7 Speed, 14-28T, 435g
Combination of 14, 16, 18, 20, 22, 24, and 28T
4). QS Bicycle Brake Handle Levers
5). QS Bicycle disc plate
6). QS 205 35H V1 e-bike hub motor
Please refer to below link:
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65972&start=975#p1294190
If any interested for these products, Please feel free to contact to us.
Warmest regards,
QSMOTOR.
