You need lots of power to benefit full advantage of a big hub motor. If I was building with that motor, the battery would be suitable to feed 500A. This means that using low C rate cheap cells, you will have to carry them in a trailer after your bike is filled with all it can hold.
Stop buying cheap batteries, or replace your big motor with a smaller one. Compare with combustion engine performance: if you build with a 1000 hp motor, you must plan high octane gas and a big fuel tank.
