Jay64
Time for me to start working on wiring up my controller. I know I am going to have a few questions on this one, the contactor was hard enough. :lol: I got a Kelly KD72401,18-90V,400A,PM with Regen controller. I am going to be using it with a Mars Etek RT motor. I guess my first question would be how do you guys connect to the large lugs on the controller? The B+, B-, and M- ones. They are quite large, so I am assuming there isn't a slip on connector for that. I was thinking that I would just use a bolt and nut to secure a looped connector onto them. Is that the best way? Seems to make sense to me, but I just don't want to find out later I did it assbackwards. Also, the manual makes a distinction between PM motor controller standard wiring, and 72v PM motor controller alternative wiring. However, they don't specify anything about this. Is the only difference if you are going to be running 72v as compared to running less volts? I mean, why would I use one compared to the other, besides the amount of volts I would be running? Also, the manual shows wiring for a 0-5k ohm throttle, and wiring for a 0-5v throttle as part of the same schematic. Do I just use one of these depending on which throttle I got or do I some how need both???
Once again, I already have the contoller and motor, so I am not at this point asking about which ones to get, but rather just how to wire them together.
