wesnewell said:
Lots of nice pictures in that bike link, but absolutely no useful info when it comes to the electrical system specs other than nominal 36V.
Sorry for the wild goose chase. Not smart in retrospect. I get hassled for no pictures a lot & for once had a link to a pic right handy. My intended point is its a nice bike w/ assumed better than average electrics like controller, but well hidden specifics, as they all do.
wesnewell said:
IMO, most battery packs with bms's have the LVC set way too low. I've heard of lifepo4 cells set for as low as 2.1V per cell
yes, i have seen similar since u mentioned it
wesnewell said:
, which imo is way too low, even though it may coincide with the manufacturer specs. But they spec it at a 0.2C amp draw and take it to the absolute minimum voltage to squeeze every little bit put of it so they can show higher capacities per cell. At 2.7V almost ever bit of useful power is drained from lifepo4. Just like rc lipo is at the same point at ~3.3V per cell even though they state it's 3.0V per cell.
very naughty of them to tell such deceptive and risky fibs about lipo.
wesnewell said:
The main concern for any battery pack is that it's rated to provide a minimum max amp output as the max amp draw of the controller you use.
Yes, which is why i get cranky about stock limn batteries sold to noobs. They almost never do. they sell 1c 350wh battery on a 350w battery, and within minutes, its much weaker than 350w.
Pls excuse my tardy thanks for your kind reply. You spun me out a bit. Just when i thought i had this stuff down, u throw me a huge curve ball i hadnt thought of - controller LVC.
Ie, what if, in the process of swapping chemistries (as am in the process of expensively doing), the lvc in the controller chops off the battery when its still half full~, or damages it by overdraining it as u point out?
Fortunately, the intended lfp battery has a lvc of 2.75v per lfp cell, which i can live with. I have never flattened a battery, and i hear they dont mind much if u dont leave them in that state - charge asap.I just have to hope the controller lvc isnt much higher than the batteryS lvc (reducing usable capacity), and that the controller doesnt have a cutoff maximum voltage ~below 44v.
As it happens, SEPARATELY, on another ebike upgrade to lifepo4, it is also very relevant info from you.
My plan is to take a bike with a 200w my1016z2 BRUSH motor, from a 200w 24v yi yun controller, to a 350w 36v YI YUN YK31c controller (i theory a simple plug compatible swap) & 36v lifepo4 pouch cell battery.
The motor comes in 3 forms, each in turn having diferent 3 power range configurations. The same my1016 motor as mine is rated to 200/250/300w in 24v form on the Unite Motor wholesaler sites~, so 350w at 36v doesnt seem excessive if 300w at 24v is ok - 10 amps on the new controller. What do you think?
Its geared down about 9:1 btw (its the reduction model), so keeping rpm up should be easy. Maybe u could cook it if u rode it hard on a hot day, but sensible riding paying attention to motor heat should be a reasonable risk? - or should i modify the shunt to reduce current a bit.
Getting info is worse than root canal work, but the lvc for the controller is 31v~ it seems (hence the product code?), and the battery BMS lvc is 33v - or 2.75v per lfp cell. So the battery bms will protect against over discharge, not the controller.
A dealer told me he regularly runs this combo at 48v on a 36v yk31c controller, but no more, so the max fully charged lfp battery voltage should be ok (~43.2v i think, 3.6vx12, but only a brief state, most always sub 40v).
More generally though, it does seem a sleeper problem. lvc requirements are very different i imagine for lipo/lmn/lifepo4/lead acid.
They sure make it hard to proceed with confidence in what must be a common scenario. Surely controllers ought give folks more accessible control and documentation over LVC (variable resistors e.g.?), or should one only consider programmable controllers given a choice?
