I have a simple 36V DIY ebike. It rained a couple weeks ago (ebike was outside, battery was inside) and I rode the ebike the next day (road was still wet). Everything was fine for a couple miles, and then the motor quit. A few hours later (no rain that day), the motor worked for half a block, and then it quit permanently.
Clues:
*When I plug the controller into the battery, there's normally a small spark. After the motor quit, no more spark.
*I took the controller apart and found drops of water inside the case, and the film covering the largest capacitor was split. The capacitor metal body appears undamaged.
*One of the controller-side power wires was broken at the XT60 connector. I resoldered it, and after that the spark returned when I plug the controller into the battery. However, when the throttle wires are shorted (this has been my "throttle" for a few months), the controller makes a clicking sound, but the motor doesn't turn. (I don't have an explanation for why the power wire would have broken at the same time as the controller apparently failed.)
*Mutitester shows 36V across the battery's charging wires, but 0V across the battery's discharge wires. There *is* a spark when I plug the controller into the battery's discharge wires; I don't understand how that's possible when the multitester shows 0V-- maybe the BMS doesn't allow power to flow immediately? I measured several times, and always got 0V. I don't remember measuring across the discharge wires when the system was working, so I don't know if 0V is a normal reading. (Battery+BMS never got wet.)
Questions:
*What component needs to be replaced-- controller or BMS?
*What should I do about rain? Don't plug in when roads are wet? Buy a water-resistant controller? Buy another $12 M95-SH 350W controller and coat all the case openings with silicone caulk? Also, I haven't done anything to protect the battery internals from water.
*Should I add a 20A car fuse to the battery? I don't know if the BMS (Daly 12S 36V 20A LIFEPO4 separate port) functions as a fuse. It's scary to even think what might have happened if the loose battery power wire had shorted against the other power wire or against my thumb, if the BMS allows unlimited amps to flow through.
*Can anyone recommend a cheap on/off throttle? (not a twist throttle-- I had one and it only lasted a few months; an on/off switch should be fine, since my controller doesn't have enough power to burn rubber)
Clues:
Questions:
