Just quietly.....
Up until 4 months ago i did not appreciate the effort Cellman (EM3EV) went to, to ensure the most possible safety of his packs.
fiberglass barriers to chaffing, cell level fuses for BMS wires, heavy duty heatshrink, RTV applied with similar care as delivering babies,
BMS units that DO fully cutoff in and out until everything is disconnected and pack is either charged or discharged to resolve the fault.
IMHO, regardless of the apparent poor build, a cell balancer was used, not a proper overvoltage / undervoltage cutout BMS (battery management system)
WHY? is Simple- at 90V+ and likely 50A+ they are EXPENSIVE! vs balancer board which is comparatively dirt cheap
I just bought one to suit 14S 50A continuous and 100A peak and by the time it gets to AU is well over $100.
Typically i build with multiples of 7S 30A boards ie 2 for 8-14S and more if i want more current - cheap at ~$15 each.
Note that BMS boards also get warm mostly under load (perhaps another reason fo not using one)
INTERESTINGLY..... I'm building a 32E samsung pack for a friend right now and at just 1A charge, they get VERY warm to HOT......
this is typically just 0.27C rate of charge....Surprised me!
I myself spent $450AUD on a Grin satiatiator today as i figure i'm in ebikes for a long time and the cheapie chargers and their failures + cost of batteries will pay for itself many times over in the long run.
Anyhow I think we have learned what we needed to learn
-BMS is better than balancer
-cheap Chinese chargers may have issues periodically (i know of 8 failures all of which resulted in no charging but anything is possible)
-PAY ATTENTION when your bike is on charge and treat it with respect
IMHO last but not least, low rate charging is a good idea if you have the time EG laptop Powersupply + DC-DC converter provides ~1.5A into a 14S pack from a typical 90W laptop power supply. At this rate even with a failure or two, tough to see 75W into the battery causing a fire
k
