Hi.
Writing this thread is actually the only left thing for me to do. I've tried to solve this issue to my best without any luck.
Now I'm going to turn to you guys and really hope that you can help with a solution.
So, I run a FarDriver 72680 on my QS205 with a 72v battery but I just can't get rid of the Hall error message in the FarDriver app.
I know that the 205 has a spare hall but still I get the error code. Once I opened the hub to take a peek i couldnt notice any damage, all the hall wires seemed fine to me. However, the blue and yellow phase wires had a slight scratch which I had to cut away and solder.
The thing that I just cant figure out is that when I have the system powered on and tries to do this hall sensor test with my multimeter.
from my multimeter i put the negative on the black wire on hall sensor plug and then I go through the yellow, blue, green.
But every hall sensor is reading 9v, both the original and spare hall.
Why is that? I feel like I've been looked through the whole internet to find anything about this.
I would be thrilled if anyone can give me some tips or feedback. Just let me know if I should post any pictures.
Thank you in advance.
