Both diagrams are correct while the lower is simpler and more to my taste with series then parallel connections. Yes, for 12s 2p.
If using a 6s charger, you could charge all 24 cells at once as 6s 4p (23.2ah).
Obviously 6amps is one quarter C of that ~23ah, and those cells are probably rated 2c charge.
So instead of the possible 1/2 hour charge, it will take ~4hr to charge.
And you'll have to reconfigure every charge/discharge. (which I can confirm sucks)
I have some of the hrp meanwells to deliver 14amps at 6-22s (21-90v). They'd give you a decent 45min full charge but you'll have to set them up and should always monitor charging. That also goes for 4hrs on a balance charger though too imo, so the faster bulk charge makes more sense for me, and others.
Teslanv MW HRP https://endless-sphere.com/forums/viewtopic.php?f=31&t=68195&hilit=+hrp&start=75
I also like the gophert adjustible power supply for the digital readout and easy integrated current and voltage controls. It's not necessary to have, but can be in series with hrps for more voltage/control, power a balancer, charge a car battery, or fine tune a weak cell/cell group in leu of a balancer and pack teardown, as I did yesterday. It's a 'entry' true 'power supply'.
Gophert PS https://endless-sphere.com/forums/viewtopic.php?f=14&t=69195&hilit=+meanwell
Keep up the positive, inquisitive, and helpful attitude and action Mr Watts, we should all always strive for such and even continued improvement.
