Hardcarve1
I was never happy with the off the shelf units that look under powered, light weight and cheap. So I had just enough stuff sitting in the shed to make a RC unit but just needed to find the right ICE brush cutter. I was always looking for a straight shaft good quality unit that had a stuffed motor that was ready for the rubbish. Luck came after a few months looking when I came across a very old Echo 50cc unit that was sitting in the shed for the last 10 years.
When pulled apart the running gear was in top condition with all bearings & gears in great condition but I decided to replace all the bearings and clean the thing up. Because it's old everything is built to last and when I had the local mower man look at it he said nothing on the market looks like that any more.
It has a Turnigy 80-100-130 with CC HV100 speed controller, BEC is a Turnigy HV and the throttle interface is the via a modified Turnigy servo tester.
moderator edit to cross-post:
"Wack-Off 5065™ E-trimmer"
http://endless-sphere.com/forums/viewtopic.php?f=1&t=42411
Machined up an adapter for the engine shaft using the old spline from the ICE clutch.
I replaced all the motor screws with stainless cap screws as the originals were starting to strip the phillips heads.
I had no guard come with the brushcutter so I found an old one and made up a new mounting bracket. Others would put holes to lighten things up but I like the soloid look with no bling.
I have still to tidy up how the battery case will fit on but it's been doing some work around the yard already and the thing is so much better than a ICE machine. I had a very old pack of A123 2S6P and the power was much better than any 50cc unit that I have used. I also need to put a mesh cage around the engine to stop the fan from eating things up. What I realy want to do is charge it from a solar panel and have a true green brushcutter.
next on the list is a self propeled Honda lawn mower that my brother has sitting around.
