Hi.
After I changed new wheel with hub motor and cassette, rear shifter worked a while, then I stucked in first (climbing) gear.
The shifter stuck? When remove HIGH lever, it moves, but when move LOW lever, it not moves, it is hard to move it.
The cable is very tight.
When remove chain by hand to higher back gear (smaller Cog), and turn pedal, its return back to the lowest first gear again (the biggest Cog).
I hope that is only cable tight, but if is, I have only 1 cm cable to adjust, or buy new one.
