AF7JA
Yesterday I was working on my commuter eBike. There were two things I wanted to accomplish. The first was to switch from 27.5" wheels to 26". The other was to install a NuVinci hub.
I had the Nuvinci built into a 26" wheel and all of that was ready. Most of it was the little stuff, putting tyres on, making the cables and the like.
One thing I noticed was that it was slower than I liked. I was able to start, with no issues in the highest setting on the NuVinci. The NuVinci has a 20 tooth gear and the front has a 42 tooth gear.
Last night I ordered a 14tooth cog for the rear. Here is the data from Sheldon's Gear Calculator, the assumption is 60 rpm and 26x1.5 tyres, the table is in mph. That 17.7 is very close to what I was seeing on my test ride last night:
I am thinking of changing that order to 13t:
I have a throttle, so I also calculated with a cadence of 80rpm:
I did look at the big TSDZ2 thread. The only mention of rear sprocket seems to be about going larger. I am also very open to the idea of a larger chainring. Any suggestions or thoughts??
