Recommend me a soldering station please
brumbrum
Wales U.K
I am fed up of buying cheap and the irons breaking. I have about £80gbp to spend. Bare in mind that this will equate to about 80-100 U.S dollars worth of goods.
I am looking for a station that is heat adjustable. Mainly being used for all e-bike applications and proofed for others apps when needed.
Thanks
Andrew :D
some info
http://www.endless-sphere.com/forums/search.php?keywords=solder*+iron&terms=all&author=&sc=1&sf=titleonly&sk=t&sd=d&sr=topics&st=0&ch=300&t=0&submit=Search
http://www.endless-sphere.com/forums/search.php?keywords=solder*+station&terms=all&author=&sc=1&sf=titleonly&sk=t&sd=d&sr=topics&st=0&ch=300&t=0&submit=Search
Ill reccomend this guy if you have a sears in your area:
Nickle plate tips last a long time, variable heat works well and it has good ergonomics and tip selection.
Btw, cooper tools is sears re-brand of weller, which is pretty reputable
http://www.sears.com/cooper-tools-soldering-station/p-00954054000P?prdNo=3&blockNo=3&blockType=G3
40w may be a bit low if you wish to solder 4mm2 cable and up. better go for 80w.
i can recommend the ersa rds 80.
edit: sorry just checked the price. it's way over your limit :( can't remember that i spent that much ;)
The main problem i have with most is the Ac voltage. It is 120 U.S and 220-20 UK. The good weller and hakko ones tend to be 120vac
Do cheap 120 to 240 step up transformers exist. I undertand hakko do a220v for china but the market is flooded with fakes.
Any thoughts?
Check out your local Maplin. they do some
http://www.maplin.co.uk/productsearch?criteria=solder+station
60Watt one there for £70.
http://www.maplin.co.uk/60w-lcd-display-solder-station-218050
Or
http://www.maplin.co.uk/60w-professional-lcd-solder-station-with-esd-protection-511927
I usually use RS components, and they have a much bigger selection..but they are the much more expensive ones. I have yet to see a small cheap one that does more than 60Watt
http://export.rsdelivers.com/product/rs/ds50/rs-ds50-digital-soldering-station-eu-uk/0186719.aspx
If you are looking to remove FETS, I use an even bigger one. a 300W plumbers style iron. The FET barely gets warm. The heat and thermal mass of such a big tipped iron means the iron is only on the trace for seconds..or less
http://www.amazon.co.uk/Toolcraft-High-power-hand-soldering-iron/dp/B003A699ZS/ref=pd_sxp_f_pt
http://www.amazon.co.uk/s/ref=nb_sb_noss_1?url=search-alias%3Delectronics&field-keywords=soldering+station
Amazon UK...Toolcraft 100Watt station for £70
http://www.amazon.co.uk/Toolcraft-ST100-D-Digital-Soldering-Station/dp/B003A5UVSI/ref=sr_1_21?s=electronics&ie=UTF8&qid=1361717663&sr=1-21
Thanks Neil, i have an RS Components near my place of work, comes in handy though as you say v.expensive. Will visit local maplins :D
Nicobie, the hakko 888 can be got at 220v but from china with a 90% chance it will be a copy, i will keep looking.
