gaf
100 µW
I'm building up a front-hub direct drive kit around my cromoly Surly Cross Check. Buying from ebikes.ca, so it's either the Crystalyte HS35 or the 9C 2807. Here are the things I still don't understand after 2 weeks of reading ES, our wiki, and ebikes.ca's guides and simulator.
1. Ping Battery says this about the 60V 10Ah LiFePO4 I was looking at: "Max Continuous Discharging Amperage: 20 Amps". and "Discharging Cut-off Protection: 30 Amps"
I was going to buy one of their 60V 10AH batteries to use with the 25A Infineon controller that comes as an upgrade to the 9C 2807. What happens if the controller tries to draw (continuously) more than 20A from the battery? The simulator puts my setup at 21 amps at 100% throttle at 0% grade, but at 30 amps for a 6% grade. Do I need to be concerned about this stuff for the sake of my battery, or does the controller sort it out? The wiki guide says this "a higher total capacity is needed to keep the C-rate low enough (e.g. with a 25A controller, get at least 15 Ah)". Can someone explain this?
2. How can one determine how much time it will take for a given battery to charge? Ping sells a 2.5A, 4.5A, and 7.5A charger. Is the 7.5 going to charge 3x as fast as the 2.5?
