I got an AmpedBike 26" front wheel drive kit a while ago. When I got it I bench tested it, and it worked fine.I got a mountain bike to use it on and when I got it all put together and wired up it didn't work. I tested components until I ascertained it was the controller. When I opened up the controller I found a big resistor was cooked beyond recognition. The color bands were no longer identifiable so I don't know what resistance it was. Is there a way to get a schematic to find out or is there some other way to find out what the value of that resistor is? Is it critical, can I just put a resistor in and pray? If all else fails, what controller can I use to replace it? Any and all help will be greatly appreciated, Thank you
Jeeze, On my first ebike, I installed an Amped frt. geared motor kit. That was something like 12 years ago! The controller died on that too.
In the suceeding years, I killed a bunch of controllers and I found it seldom works to try and repair them. Soldering one thing will often kill something else, besides newer controllers have displays, have a softer start and just generaly work better.
I just replaced the controller on my Bafang SXW02 rear motored build to a 22 Amper (over the 17A that I was using) and since I didn't want to wait for the slow-boat from China, used this one;
It's a rebranded KT and I had to go with a 5-wire display as the old one had a 4-wire and I used this one:
Just a simple LED with a 3-speed limiter. I don't care about a bunch of info and three speeds is enough for a 22 MPH ebike. Took me a little while to figure out I had to turn the display on AND activate the mode button before the bike would move.
I also got a new cable just to make it easier to connect the Hall wires;
It's for a rear mount, so it will be a little long for the frt., so a shorter cable would be nice, but if not avail., it could be looped or shortened.
If your Amped kit is a geared motor, a 22A controller is perfect for it.
The only thing this controller doesn't have is cruise, but I'm ok w/that.
P.S. The Amped motor (which is actually a MXUS F07) was great. Eventually, the axle bearings got loose and I gave it to a kid in the neighborhood. The last time I saw him (a couple of years ago), he was still using it.
