ProgramThyself
1 W
- Joined
- May 20, 2019
- Messages
- 50
I have a stationary application where a motor controller that sees only intermittent use is powered by a 12 volt 10 amp bench supply. That’s a bit weak and something that can deliver 250 Watt would be better. Instead of a beefier power supply that probably has a fan, I wonder if a trickle-charged power-tool battery pack or something similar can work? 50 Wh ought to be enough. The controller (VESC 6 EDU) can handle up to 6s lithium. Also, there is sometimes backward (regen) current and it would be nice to just dump it into the battery instead of burning it in a Zener diode in parallel with the power supply.
Can this Makita pack deliver current while trickle charging?
Building battery from MAKITA Konion PACK
I see adapters for $16 on eBay. Reliability matters a lot.
