Replaced the hub motor and use a different connector
riccimar
New here
Casablanca
Hi. I recently replaced all the real wheel, complete with hub motor, of my 20" e-fatbike. The stock one was using a 9 pin branded jukes connector with a gray tip. The new one use a (apparently) identical connector but with a red tip and pins seem a little thicker, so I can't plug the new male connector to the female on the bike side. Please can you help me to find with connector is the new one and if I can find an adaptor? Thanks. In photos the new one (red tip) and the stock one (gray tip)
Yes this higo z910 seem like mine. Thanks. So it's a z910 with ticker pins (1.5 vs 1.2mm^2) and can't plug in my original z910 female. So i think it will almost impossible to find a ready to buy adapter. Inwas hoping to solve with this ine, but probably it's kt good
Je viens de trouver ça sur AliExpress :
Julet Z910 connecteur de moteur mâle étanche FV2-Z916A femelle 9 broches adaptateur Extension Bafang G062 câble moteur
Keep in mind that you may need to play with the order of the phase and hall sensor wires with a different motor anyway. Some controllers have a learning function for that.
