Hey all,
Im reposting this as I put the other post in the wrong forum.
I have a Cyclotricity 48V 1000W brushless direct drive motor. It is great when it has power but if I turn it off the cogging is bad. I don't think it's damaged but is there any way to test how much cogging it should have? Anyway i;ve got 48v 11ah and I am going to upgrade the battery to a 48 17ah or 48 20ah for range. However the main point is that I only use it in it's 250watt mode anyway. So I'd like to get a new motor/controller/battery. So what's the best and cost is no issue at all. I'm not interested in power, per se, as I never use it at 1000w but I do haul a trailer sometimes. I've looked at golden motors but have no experience with them. Crystalite? Mac? What should I buy? I'm interested in range and top speed. Don't do any hills really so no mid drive as I like the direct drive no pedalling for power somtimes etc.
Desired max speed on level ground. mph or kph
25 mph
Desired max range at what cruising speed. mph or kph
40-60 miles? More if possible
Preferred bike wheel size, or wheel size of bike you want to convert. Most common kits are for 26" wheels.
29er
Brake type of motor wheel. Disc or not.
disc hydraulics
Rider weight.
80kg
Terrain. Exp: mostly flat, some short hills under 20% grade, I want to climb mountains, etc., etc.
Mostly Flat
Budget.
unlimited
Tia
25 mph
29er
disc hydraulics
Rider weight.
80kg
Mostly Flat
Budget.
unlimited
Tia
