Hello,
I have just bought used electric scooter with damaged hub motor. It was totally blocked with rust between magnets and rotor. After pushing rotor out and cleaning everything motor started to work - but it doesn't work as it should. I found, that one hall sensor is dead. There is spare set of hall sensors, but none of them are working.
The only solution that I see is to replace hall sensors. The problem is that it is not possible to see what kind of sensors is used here. Could anybody suggest me what sensors could fit here? Motor is "Super Power Motor" 8000W, 72V. Controller is from Kelly controls. Scooter brand is "XEL", but I have found, that they are also called ZEV LRC.
If there is not enough info, just tell me what I need to check more?
Some photos are attached here:
