dogman dan
1 PW
Once you get into good suspension forks on bikes, they will be alloy. I had to do quite a bit of very carefull filing to get my motor to fit alloy forks. The fit on alloy forks is very very fussy. It's really easy to mess up if you don't really know what you are doing. I found it was needed to file both the dropouts and the motor axle to fit mine so the fork didn't bind. You need the c washers, homemade or from ebikes-ca and two torque arms. The experience I had from many other ebikes gave me the confidence to attempt alloy forks. If you get it wrong, new forks may be $300 or more!
To fit a motor, you are looking for suspension forks with the dropouts on the inner edge of the tube. Ones with the dropouts centered on the tube may not fit.
