Sunder
Hi all,
Not sure where to put this, but this is probably the closest match...
I have a technical issue that I'm sure the more technical guys here will be able to answer. I have a LED headlamp that from 8v-32v, draws exactly 40w. So if I lower the voltage to 8v, it draws 5A. If I raise it to 20v, it draws 2A. So far so good right?
Problem is, my motorcycle controller complains if it detects greater than a 35W draw.
If this was an ohmic device, it would be easy to put a resistor in series, and just drop the entire circuit to 35w, and the bulb will get a little less.
But is there any way I can do this with a device that draws a fixed load regardless of voltage??
Thanks.
Thanks.
