Gentlemen
I've been running a large Turnigy outrunner in an electric outboard motor leg with different RC ESC's and have become tired of ESC problems (another story).
I wish to use an electric bike controller but need to be able to reverse the motor direction which I currently achieved with two relays, swapping two of the phase wires. My concern is, if I have to fit Hall sensors to the motor will I also have to switch these to achieve reverse? and what would happen to the 'timing' of the sensors?
As this application has very low starting torque I would be quite happy with a controller that does not require hall sensors as is the case with RC ESC's, can you suggest a suitable controller?
The installation is 24V and I normally run at 300-400w but on occasions it is desirable to have 700-800w available for emergencies.
This morning I tried an Ecrazyman 12v 18A controller to see if it would run sensorless, without success. I also have a GNG1 48V 480w controller but am not hopeful that that will be any more appropriate.
One possible solution might be the Golden Motor BAC-0501?
Your comments and advise would be greatly appreciated.
GeoffV
GeoffV
