3000W electric motor for electric scooter upgrade in perfect condition. can be tested on site.
Also suitable for thermal scooter => electric conversions. (possible to advise you for serious buyers)
With Michelin 2CT 120/70-12 tire + new brake disc, never used, supplied with its screws.
Characteristics:
Rated voltage: 72V
technical information: (technical sheet in photo)
Torque: 150 N.m
Supports overvoltage up to 92V
Supports regenerative braking to brake while charging the battery.
Maximum power 4000W (maximum legal for scooter class B in europe)
Additional Hall sensor with temperature sensors.
Sold with a Sabvoton 72V 150A controller compatible and already programmed with this motor. Bleutooth key supplied with the controller to configure it with a mobile application via Bluetooth (see photos for the technical sheet)
Very easy assembly (plug and play). the motor connections go directly to the controller as well as the accelerator signal converter.
Price purchased new with delivery to Belgium and taxes :
Engine: €495 + €65 for the Michelin tire.
Controller: €250
Asking price €350 for the motor and €150 for the controller. Which will make a total of 500€ for the complete kit.
Front wheel 110-70/12 without the rim will be given with the package if you prefer.
Sale because I no longer have any use (scooter sold with its original motor).
Pick up in Mons Belgium or send at your expense (box on photos with dimensions and weight).
Characteristics:
Rated voltage: 72V
Torque: 150 N.m
Controller: €250
