Now I'm curious, John.
Please post pictures of what you consider to be original Sony cells and point out the details that in your view make the cell shown a fake.
Apart from the large sticker I don't see it.
these guys here have some faint writing on them...
With a bit of photoshop, looks like it says:
top line: can't tell...
middle: "T V3A2JVE21N"
bottom: "Sony 31"
John, I have below rated capacity because I discharge only to 3V. icharger limitation doesn't allow me to go any lower. But 2100mAH at 3V doesn't seem too bad. Especially with my wiring creating higher resistance.
I'd guess I'll have the same results with the cells schwibsi is going to send me.
On the cell it's written:
SE 18650V3
T V3A2JVE21M
Sony 31
Sorry if I missed it but at what rate did you D/C that cell in amps?
otherDoc
Whoops! I just saw the 2 amps rate. So that is 1C
Does anyone remember the C rate of the 18650V or VT and what D/C rate would it tolerate. The reason I'm asking is that I am still using 6 Fatpacks (12 ah) paralleled with a Ping 10ah and the system works fine on a daily basis in my wife's trike. The Ping is about 4 years old and the Fatpacks around 3.5 and it all still works for a total of about 19ah at about a 10 amp rate? The Fatpacks cells still are close in voltage even at this date without balancing. John?
I did few discharge test from 4.2V to 3V:
- 2000mAH at 5A discharge for V3 cells. Both of them. So identical capacity to the ones I have
- 1800mAH at 5A discharge for V4 cell.
I'm doing cycling them now and see how that goes...
