izeman
1 GW
Why did you put the chain tensioner on the powered side of the chain?
Edit: sorry. I just realized that's the human powered chain. Everything ok
boisrondevens said:cnc parts
Stielz said:Looks bloody good mate. Keen as to see some video.
How does that motor handle a bit of abuse? Any problems with overheating?
redline2097 said:I am planning to build my kids trial bike with RV 120 pro and this controller http://kellycontroller.com/kbs72181e110a24-72v-mini-brushless-dc-controller-p-1315.html what you think?
What kind of a AH your pack has and how far you can reach with it? We are currently having 60v 15ah but is it enough?
redline2097 said:What smallish controller you recommend for rv120 pro? Size wise I can't fit wider than 120mm.
straby187 said:What size is the spring on your rear shock. After you extended your dropout did you not have to go up in spring rate..?
oatnet said:boisrondevens said:cnc parts
Nice Job! Your version of the replaceable dropouts is awesome, are they steel or aluminum? I did a build with a stealth bomber motor in custom dropouts on the same frame, that A-line frame is a BEAST, one of my all time favorites.![]()
Oh shoot I just noticed the front-mounted pack too, nice mounting technique. I pioneered the front mount to double crown fork here (pelican boxes with aluminum weight clamps, link in my signature) and faced a lot of nay-sayers, but once you get used to it, having the weight up front is significantly improves handling. I still believe it is the best location for the battery on street bikes, not so much for an off-road/wheelie duty cycle. 8)
-JD
boisrondevens said:Your built was the reason y I fall for that frame![]()
I had the batteries on the front fork before but the feeling I had with 20s 16ah was a bit too annoying for steering
macribs said:What material for battery holders? How will those holders work with bars or welds? I just can't picture it in my head.
