SnowDog2112
What should I use for rim tape.
Sure enough, my rim didn't come with rim tape. Got lucky, since the tire went flat while the bike was loaded in the car, on the ride home. (You guys were right, check before assembling!)
So, since I'm removing the quirky roadbike tire it came with, I decided to replace it with my original Mountain bike tire. I thought I would be able to use the rim tape from it. It turns out it's kinda narrow. It will cover all the holes if I position it right but by the time I get the tire and tube in place the tape will shift and expose some of those sharp edged open spoke holes.
Will I need something stronger and wider? Where to get it if I do? could I get away with just using some pieces of adhesive tape to hold it in place?
