RIPPERTON
https://www.youtube.com/watch?v=U88eN0xY7Js
https://www.diyelectriccar.com/forums/showthread.php/rippy-kart-189498.html
Thanks.Nice work on the motors.
fechter said:I would think the independent motors should work well as a differential, but I guess you're seeing otherwise. Increasing the gearing should be pretty straightforward and should also help with the steering issue.
Quinc said:Why not mount the batteries under the steering? Wouldn't that help with getting more weight on the front tires?
Yes , you are in virgin teritory for kart handling with a diff.RIPPERTON said:During the turn exit, both rear wheels are gripping to the point of causing the understeer.
This doent happen in a jacking kart.
Now all I have to do is fix the understeer. I thought the controllers would comply to the differentiation in the rear wheels.
Im going to start by moving the battery boxes forward about 15cm, then move the ctlrs out to the side.
StuRat said:Awesome! I want one.
nuxland said:Just for curiosity What is your sprockets sizes for 120km/h.
RIPPERTON said:Pic showing LiPo cell swelling. This cell was low voltage. Not sure what causes the swelling.
