MarkJohnston said:I forgot to mention with those brakes that broke. They would make an extremely EXTREMELY loud noise whenever they would build up heat. I tried to look it up on cycling forums to see if that was normal. The best thing I read was that it's normal for the metal sintered pads to " HOWL" I am using those types of pads. It was a very loud screeching noise, not sure if you guys have the same thing. It was so loud in fact that I people in cars would turn and look at red lights . Scrrreeeeech. :lol:
They get hot and noisy QUICK.
I wonder why the hope tech v4s are " only a half step down from a motorcycle brake" they look tiny and just like all the Shimano saints.
I have a BR-MT520/501 combo on the front of one of my bikes (the same 4-piston Shimano that you have). In my experience, it is a great brake. Basically the same performance as the Deore/SLX/XT 4-piston (even has ceramic pistons and servo-wave lever) but painted black and marketed as an OE ebike factory brake. Mine came stock with the Shimano resin pads and it was very quiet with great performance. Living in a very hilly area with long downhills on one of my daily rides, I wanted to try metallic pads.
I got a 4-pack of the best metallic pads Aliexpress had to offer for 15$. I’ve had the exact same howling/resonating problem as you. Glad I tried them first and not the 40$ Shimano metallic. The performance at the limit is good, metallic pads don’t fade. They are quiet as long as you are braking HARD. The problem is for 90% of braking they don’t get hot enough and with light to mid pressure (10-60% or so) they cause the rotor to resonate and it’s loud as hell. I have a 203mm floating rotor btw. Cleaned them way too many times to confirm although it does get a bit better when pad material is distributed on the rotor, and also, as the pads wear. I think the resonance is basically caused by too-high coefficient of friction on the pads/rotor so when they grab the rotor at lighter pressure it basically stops/moves many, many times/second (the flex in the rotor and hub allow this against the rotating wheel). This resonance has also broken spokes in a well-built front wheel. I will be switching back to resin/organic pads after my stock runs out.
