Hi,
I recently purchased a brushless kit to upgrade my old IZIP ecoride 2 that was using a brushed motor with a 24V battery. The battery is recent and was expensive so my idea was to purchase a brushless kit that would work with 24V, however this is not what I received, instead I got a 36V controller with a min voltage of 31.5V. Therefor it doesn't work with my 24V battery.
The kit was rated at 500W but I have the possibility to set up the max amperage with a LCD display, my idea is to change the 36V controller to a 24V controller (such as https://www.amazon.co.uk/Electric-Brushless-Regenerative-Function-Controller/dp/B01H56INEQ/ref=sr_1_7?ie=UTF8&qid=1511335970&sr=8-7&keywords=24v+brushless+controller) and to limit the amperage to what the 24V controller can sustain but before doing so I have a couple of questions.
- What would happen if I run this "500W 36V" kit with a 24V 11A controller (which makes 264W peak power) ?
- Does the motor would run extremely slow or it would just be a 264W motor that run normally ?
Thanks
Thanks
