mushymelon
Could someone recommend a battery and charger for the upgrade
I would like to go to 18v if possible a little more Go would be nice.
Heres the specs.
Ryobi 150r 12v electric weed eater
Original battery is a 12v 8ah gates SLA
Heres the switch
There is a thermal overload switch. I think a bypass is in order here.
Image of a replacement motor.
I have not opened up the motor housing yet but it should be similar.
I dont know the specs.
Im planning on keeping some battery wire and the connectors external for easy charging.
Can the switch handle an extra 6+ volts ?
Can the motor handle and extra 6+ volts ?
What charger and battery would you recommend ?
I am in ontario is there anything restricting delivery here?
Heres the specs.
Heres the switch
