s700 lcd series: controller/communication protcol?
gvdb
Geel
Is it possible to connect a raspberry pi / aruino with tx/rx lines. What protocol is used on these type of controllers
There are a few threads (usually with protocol in the title or first post) that discuss details of some of the protocols of some systems; I don't know if the s700 has been.
Some discuss how they found the info they did, so you could use the same methods to reverse engineer the datastream of this LCD, by monitoring what is sent between controller and LCD for each specific action, reaction, and situation, vs what you see on the display and what happens at the controller.
It's possible some of the opensource firmware osfw projects here and on github, etc., have protocol data, especially the ones that use a regualr OEM LCD but OSFW on the controller end.
Hi,
I have written a program for STM32xx and x86 Linux for testing.
This is just a portion of C++ code; I need to document it, so I'll provide a link to a zip file."
#ifndef __ISYS_S700_H__
#define __ISYS_S700_H__
#include <isys/main.h>
#include <isys/hash/hash.h>
#include <isys/time/time.h>
enum {
S700_RX_ELAPSE_TIME = 2000,
S700_IC_ELAPSE_TIME = 4000
enum S700_ERR { // S700 DISPLAY THIS ERROR
LOW_BAT = 0x08, // 00006
MOTOR_ERROR = 0x40, // 00007
THROTTLE_ERROR = 0x20, // 00008
CONTROLLER_ERROR = 0x30, // 00009
typedef struct { // OFFS DESCRIPTOPN
uint8_t _00; // 0. 0x01
uint8_t size; // 1. 0x14 size
uint8_t _02; // 2. 0x01
uint8_t drivingMode; // 3. P10 (0=assist, 1=throttle, 2=both)
uint8_t PAS; // 4. P05 (0=3=0x05, 1=5=0x03, 2=9=0x01 assist levels)
uint8_t nonZeorStart; // 5. P09 (0=0xA0, 1=0xE0)
uint8_t speedSensorMagnetCount; // 6. P07 (1 - 100)
uint8_t _07; // 7. 0x01
uint8_t wheelSize; // 8. P06 (xx ^ 128) + 128 = (256 for 25.6", 260 for 26" ...)
uint8_t PAS_sensitivity; // 9. P11 (1 - 24)
uint8_t PAS_starting_power; // 10. P12 (0 - 5)
uint16_t speedLimit; // 11. P08 (0 - 100) BIG ENDIAN!
uint8_t currentLimit; // 13. P14 (1A - 50A)
uint8_t reserved[4]; // 14. ?
uint8_t PAS_type; // 18. P13 (5, 8, 12)
uint8_t csum; // 19. CHECKSUM XOR
inline double get_wheelSize(void) {
return (double)(128 + (wheelSize ^ 128)) / 10;
} __attribute__((packed)) S700_RX_t;
typedef struct {
uint8_t size; // 1. 0x0E size
uint8_t ERR; // 3. S700 ERR
uint8_t COM_ERR; // 4. COM ERR
uint8_t reserved0[3]; // 5. ?
uint16_t pulseTime; // 6. BIG ENDIAN!
uint8_t reserved1[3]; // 10. ?
uint8_t csum; // 13. CHECKSUM XOR
inline void set_pulseTime(uint16_t pt) {
pulseTime = pt > 0 ? (pt >> 8) | (pt << 8) : 0xFFFF;
inline void set_csum() {
csum = hash::XOR8(this, sizeof(*this) - 1);
} __attribute__((packed)) S700_TX_t;
#endif
