aleikxandro
🔌 New-ish
Hello everyone,
I'll try to explain my situation so that anyone who knows something about CAN communication or how Ixxats work can help me.
Alright, so I'm building an electric motorcycle, and I've got an inverter Gen4 Size6 (I attach the images) 72/80 V nominal voltage and 500 A peak current. I also have a PMAC motor which is not the problem, becuase it has been tested on a test bench and it surely works. The main problem comes with the communication program and the Ixxat USB-to-CAN V2 compact con D-Sub-9 with galvanic isolation.
So, I know they are quite easy to break and they tend to when not manipulated properly, and this is a very important step to be able to communicate from my computer with the inverter, since the program used from Sevcon (Borgwarner), DVT Customer Application and CAN Analyser 3 Mini with the VCI Driver installed and updated, specifically need an Ixxat of the ones I have attached in the third image to work properly. In addition, they say that if it is any other type of Ixxat than the 3 shown in the images, it is not sure that they will work as they have not been tested.
We have made measurements and tests, we are practically sure that our Ixxat is broken, it does not send or receive data, although it recognizes the CAN bus, it does not recognize the CAN communication and gives errors for everything. Although we have tested it with different Raspberry Pi systems, computers, inverters and laptop, etc.... Fixing it is not an option due to time and shipping issues. I would like to know if anyone knows of a cheaper Ixxat (because they are usually quite expensive even exceeding 300€) that works for my inverter model and can communicate with it from a laptop or microcontroller easily. If someone can help me to recognize the CAN and configure it so I can start with the programming of my inverter and test it with the engine on a test bench I would also appreciate it. I will also attach the main errors recognized by the microcontroller. I'll try to explain my situation so that anyone who knows something about CAN communication or how Ixxats work can help me.
Thanks a lot people.
