riba2233 said:How much was it with the shipping?
ecruz said:About $1,895.00 not counting brackets
Looking at those data PDFs, they show a cycle chart going up to only 350, what happened to the good old days where they would show like 2000 cycles?Ebikebert said:These are new cells for high power applications that have both more capacity and more punch. I have attached some data sheets showing some results for these cells from the manufacturers. Both of these cells have a max continuous discharge of 20A and a max pulse of 35A while still having 2500mah of capacity!.
Ahh so annoying ebay.com.au (where I go by default) because so many sellers do ship international but so many sellers don't show up at all if you use ebay.com.au vs ebay.comecruz said:I bought them from r-lsales on ebay. The brackets from Supower.com or supower on ebay. They spot weld but I did mine myself.
andreym said:I have not tried more than 0.3mm thick, But manufacture tells it is able to weld up top 2.6mm (what i doubt)
but up to 1mm thick I believe it would not be a problem, as i use only ~1,5 setting from max 10 available
here is the link if you can talk Chinesehttp://item.taobao.com/item.htm?spm=2013.1.0.0.X4fW1i&scm=1007.10011.531.0&id=1029910039&pvid=ad49c28b-b749-439d-996a-84806110b424
Hi RR sp?RiverRat said:http://battery-star.en.alibaba.com/product/1833435904-220647293/us18650vtc5_2600mAh_3_7V_battery_30amp_battery_high_drain_battery.html
Hi first post but long time reader. Im about to make a couple of packs my first attempt. These seem rather cheap and I think I'll be happy with any of the batteries mentioned in this thread. Wondering if this company is legit ?
Cheers
Mammalian04 said:So it looks like Supower prices are quite a bit higher than other sources. Is this mormal (I know they provide spot welding and and battery spacers)?
cal3thousand said:Mammalian04 said:So it looks like Supower prices are quite a bit higher than other sources. Is this mormal (I know they provide spot welding and and battery spacers)?
Where do you see better prices? I was under the assumption that they are competitive and, most importantly, reputable quality cells.
nukezero said:cal3thousand said:Mammalian04 said:So it looks like Supower prices are quite a bit higher than other sources. Is this mormal (I know they provide spot welding and and battery spacers)?
you have to buy in larger quantities to get a good discount.
Mammalian04 said:I am buying 560 to 620 cells. I have read he'd out to some other vendors with some history on Alibaba. While it is not guaranteed, at least they have been a seller for several years...
nukezero said:Mammalian04 said:I am buying 560 to 620 cells. I have read he'd out to some other vendors with some history on Alibaba. While it is not guaranteed, at least they have been a seller for several years...
I don't know about buying from these vendors who haven't been verified by the ES community. At least with supowerbattery, we know they have came through for atleast 5 people here on ES that I know of. With that kind of money going overseas to China, it is a huge gamble, but I guess somebody's gotta take that first jump with anything new.
Mammalian04 said:nukezero said:Mammalian04 said:I am buying 560 to 620 cells. I have read he'd out to some other vendors with some history on Alibaba. While it is not guaranteed, at least they have been a seller for several years...
If they really are in Shanghai, I can probably have someone go check them out in person. The tricky part is knowing the quality of the cell and whether it is genuine or even "old stock" that has been rewrapped...
