This may not remain titled the same, but for now, SB Cruiser Mk II will do to get the idea across.
So...I've been rebuilding the original SB Cruiser here:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=67833&start=350#p1227053
to fix a bunch of "little things" and make it more useful.
But there's a lot of things I can't "fix" without starting from scratch, or doing so much to the old one that it'd be a lot easier to do it from scratch, anyway.
So this is going to be ideas on what exactly I'd do if I were to start over.
It needs to be able to handle quite a bit more cargo (or dog) and accelerate a lot quicker than SBC even with that cargo on there, *and* the trailer attached, also full of cargo (or dog). Preferably both the dogs, at least, in the cargo deck area, so I don 'thave to use a trailer to carry one, with the other on the deck.
Also needs a lot more range than the other one, preferably also while hauling the max cargo, but I don't expect I can manage that. The best I can do right now is both the A123 and the EIG pack at the same time, plus whatever that old Luna pack can put out when paralled with the others (by itself it'd probably just burn up at these loads).
First up is building the deck area frame more like my Mk IV flatbed trailer here:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=76539
so it's lower for better stability in turns and such, especially when loaded down. The Raine Trike (on hold) would be built this way, too:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=80951
but it's meant to be smaller than SBC, and SBC Mk II (SBC2) will be bigger--at least a longer cargo deck, and wider if I can manage it, because I don't need this one to go thru my front door. It'll be built to stay outside, albeit parked in the shed or something like that.
Motor drivetrain won't be hubmotors, but will be a central motor driving a differential that runs both wheels. I'll probably use large-diameter wheels, because they'll ride easier...I don't knwo if bicycle wheels will survive this, but if they dont' I'll have to see about moped/motorcycle wheels.
But they wont' be directly mounted to a transaxle, most likely, as live-axle wheels, probably they'll be driven by short chains from the transaxle ends. Otherwise I'll need to make some hubs to get the bike wheels bolted to the transaxle; I might be able to use some old powerchair hubs I have for that, if they fit teh axle, or if I can lathe them out to do so.
I dont' think I have a good diff, though, that could directly be used. I have an old powerchair with a brushed motor / transaxle combination (the chair itself was destroyed in the housefire, and the motor seems to be toast, but the diff is probably fine, just unlikely to be made to take the torque/power I need).
I might have to bulid one, and not being sure I coudl do that, I might have to buy one. :/ The peerless-type diff is what's been recommended to me a few times for the other trike projects, and this type:
http://www.staton-inc.com/store/index.php?p=product&id=179
http://www.northerntool.com/shop/tools/product_35768_35768
is typically around $140-$150 on various places online; if it seems to be the best option I'll put up a want-ad here on ES and see if anyone has one cheaper, cuz I dont' have that kind of money to spend.
The motor...I don't know yet. Probably the old powerchair BLDC motor I havent' yet gotten to use in a project, powered by an ebike controller. Might be something better; I've been advised a care package is being sent of some stuff; we'll see when it gets here if I can work with what's in there.
It will still be pedalable, albeit at an extremely low speed, just geared very low (like I just did to SBC) so I can accelerate it very slowly and keep going to get home in case of drivetrain failure...but I dont' know that I can put the pedasl thru the peerless diff; if i do and that's what fails, I'd still be screwed. Could make a separate pedal diff to input to the wheels, but..I dunno. Anybody else with any ideas?
I might also put the 1000w Fusin geared hub in the front wheel, but I dunno that it will be able to haul this thing very well for very far--it's just not geared for the super-low speeds it would probably have to be used at if I ever did have to use it as an emergency backup drive. So probably just a regular front wheel.
Basic layout, mostly like the SBC, though we'll see about a bit more elegance along with the functionality; depends on what I end up building it with, as that's the limitation I've got.
Will work some design ideas out and sketch them up to put here.
If anybody has ideas they're welcome to post those too.
