grindz145 said:
I can't believe how awesome that is turning out!
It looks really hanebrink like:
That thing begs for some ice tires
Love the Hanebrink. Perfect design for an all purpose eBike really.
Just come up a bit sort on the funds for one.
I see the resemblance with ScootBike. I think I look a bit sportier/Kooler.
Would burn a bag of puppies for that front end though.
Updates...
I have the drops. stretched out to 210mm with a 36" clamp, reversed for spread mode.
If I leave it like this for a while will it eventually conform? Do I need Heat? Any other methods you can suggest?
Clamping Dropouts. Inspired by Dogman. :wink:
Proposed bolt hole pattern on angle iron clamping dropouts.
Any thoughts, criticisms, opinions welcome & wanted.
I get one shot @ drilling this out. :?
I plan on clamping the angle to the drop., then hand drill/tap holes through both.
Bad Idea? Better ideas? Help.
A second angle or piece of flat, then bolts/clamps to the first.
Accommodations for wheelbase adjustment.
Out of time for now. Any thoughts?
Stay tuned...
