The charge level is displayed on the battery icon in the middle of the screen. However, as you can see in the photo, it appears as if the battery is empty — even though the system shows a voltage of 40.2V just below it.
This suggests that the display is likely calibrated for a 36V system, and is not correctly interpreting the voltage from my battery (which may be 48V or higher).
Because of this mismatch, it always shows the battery as empty even when it has charge. I'm wondering if there’s a way to reconfigure the voltage settings on the display to match a 36V system so that it shows the correct battery level.
If that's not possible, would I need to replace the controller and the display with compatible components to fix this issue?
