Wisent1998
🧲 New user
Got a scooter to refurbish and it just needed a battery replacement. Ran fine for a few days until I turned it on and it showed an error.
Opened it up and everything was sitting in a pool of water. It was still charging (not smart but I plugged it in without knowing it was wet inside at the time).
Dried it off
The hall sensor wires and the other ones( display and throttle I think) were slightly deteriorated so I soldered them together then booted it up and the motor was making loud noises while jerking when I pushed the throttle.
Tested the voltages across the hall, all good.
Checked for phase shorts, all good.
Tried to plug the battery on charge but it blew the charger this time. Checked the battery output and it was sitting at around 41V which makes me think it’s still good. The input for the battery was also sitting at the same voltage is that normal?
Opened the motor controller up tested the mosfet diodes, all good. But I noticed one of the bridges was burnt out and I thought I found the root of the problem so I soldered a bit of copper wire to close the bridge. Then tried to plug the battery back in and it blew the connectors.
Now I don’t know what to do.
Was thinking I could try another charger for the battery to see if that’s the issue but I don’t want to break another one so I could try to repair the original charger to see if the battery will charge.
I have a video of the scooter jerking and making noise when I push the throttle but idk how to upload it on here.
Dried it off
