wojtek
hi,
finally i got my scorpion and now working to install battery boxes. The idea was to put them as much in front of the trike as possible. However it is quite not that simple. I am thinking to put one set of batteries beneath the front boom - i will prob get those turnigy long packs [30cms long] as i have around 44cm available there. the other box will go under the frame in central part of the frame.
The controller will probably go underneath the front seat. i am however tempted to use falco wireless kit - it would make this build super clean!
Re the mounts i found this nice little thing:
http://www.fish4parts.co.uk/Plumbing.81/Pipe-Clamps-%25252F-Clips.10930243/Fast-Fix-Pipe-Clip-Rubber-Lined-54-x-M8.101335.html
Rubber lined pipe clamp. They are great as fully covered with rubber protecting the frame against scratches and also with welded heavy duty nuts...
So im hoping 3 of those are enough to hold a box with 5 x 22v5000ah batteries. Those clamps look quite massive. Later on i will drill 3 holes in the box and screw the into the clamps. It will give me 9cm clearance off the ground... hmm not much.
The bottom side of handlebars are 13cm off the ground.
I had to put one clamp further back as there was no space to quick release in order to fold the trike.
actually i could probably fit all batteries to the front boom!!! it will look silly yes, but great for handling and cornering!!!
alternatively i could also put few long and thin turnigy packs under the seat.
Unfortunately i touch the box with my legs when put under the seat in front...
