Scrub Psycho II mountainboard build
Hi!
Thanks! Not measure the distance. I ride cca. 10-15min etaps and recharge 1500-2000mAh maybe.
Yes, only one battery use, and replace. I will buy 5000mAh.
"New" beast in da house :)
MBS Pro 12 Jereme Leafe edition from 2006 :))))
Go electric!
Thanks!
You think the u-bolts mount on scrub? Yes its working fine.
Your MBS pro 95 Jereme edition or old pro 12 ?
I see many mount solution in ES topics. Maybe i will make an L bracket to brake mount hole.
New video:
Turning.
[youtube]SF9Aix246DM[/youtube]
Sorry for video transitions :)
Great build, and good luck with the MBS board; would love to see a build thread of that.
What app did you use to measure your ride time and speed?
Hi!
Thanks! MBS conversion finished, i will make a build thread soon :)
Here is the app:
https://itunes.apple.com/us/app/speed-pro/id405087651?mt=8
(I used the old ios6 compatible version)
Hi Vlaca,
Awesome mountainboard setup!
Could you tell me where i can find this parts? I have the same board and i want to upgrade it but its a bit difficult to find everything ...
Thanks!
Hi!
Thanks!
The motor mount is 6mm alu plate (i found in a little local factory).
The sprocket: 6mm ISO04 chain, 10T/45T sprockets (from Conrad webshop)
http://www.conrad.hu/conrad.php?name=Products&cid=1210057
