JesseW
Hi all,
I'm new to the forum. I've spent a fair bit of time poking around the forum and the web and I'm going to throw out a request for some advice as I'm finding it a bit challenging to compare all the bits of data.
I have a camp supersonic folding bike I'm planning to convert to ebike.
https://campbikeusa.com/collections/camp-supersonic
My goal is to have a light weight compact bike that cruises at 25 mph, power to 30 might be nice but the bike isn't really going to be safe at those speeds to 25 max would be OK.
I currently have a 2016/17 Rad mini which I like but I'm trying to make something lighter, more compact and with standard narrow wheels that will go on a public bus rack. Bike will be used for commuting and generally getting around without a car.
Rear drop outs appear to be ~137mm.
I'm planning to mount batteries on the rack.
Tentatively planning to house the controller between the rack and frame in an enclosure.
Want to have PAS, throttle, and cruise.
Planning to upsize the front chainring to be able to pedal effectively at up to at lease 22mph
Planning to upsize the tires as much as the rims/frame will allow, frame looks like it would fit ~2" tires.
I plan to use torque arms and secure them somehow to the bike frame.
Planning to build my own batteries from 18650 cells possibly a big one for long range and a small one for lighter weight running around town. 48 or 52v.
So my main questions are:
I think I want to go the geared rear hub motor route for lighter weight. I'm leaning towards a MAC motor although I'm not sure this is best with the high RPM needs of a 20" application. It looks like the rear disc brake has the required 15mm clearance to work with the MAC hub. Is this a good idea or does anyone have a better recommendation based on my goals?
Controller is what I'm really wondering about, I understand basics of hall sensors and brushless motor controllers but would appreciate any input on best controller for this. I'd like the option to run at 48 or 52 volts. Ideas?
I don't totally understand display and cruise options. My frame of reference is my Rad mini. I don't need a fancy display but a cruise control feature would be nice. What setups work good for commuting and city riding?
Any other challenges or pitfalls anyone sees with a project like this.
Thanks so much in advance for any help anyone can throw my way!
