Jeremy Harris
Ratking said:Jeremy,
I find it interesting that you actually can build a controller that may work better than a Chinese one. I admire your work, to bad I can't learn everything I want in detail. Do you think this controller can drive different mosfets? Since you want to use it at some very big mosfets? If so, this may be one really good controller for all the guys trying to get the rc motors going.
Ratking
The design as it stands will drive pretty much any FET you want. The key thing with driving FETs is to make sure that the gate drive current is adequate, and free from any ringing or noise. The drivers I'm now using are capable of driving 2A maximum into the FEt gates, far more than would be needed even for a multiple FET controller. By comparison, the XieChang/Infineon controllers typically drive the FET gates with only around 0.13A.
This means that this basic controller can be adapted to drive a fairly wide range of FETs, perhaps with just a change of gate drive resistor to ensure stability and set the gate drive current to the right sort of value for the total gate charge of the FETs being used. For example, the gate resistor on the XieChang controllers is 91 ohms (giving 130mA peak gate current from 12V) whereas that on my controller is 10 ohms, giving a peak gate current of 1bout 1.2A, probably a bit high for the FETs I'm using.
It doesn't make sense to use FETs in small packages to drive big RC motors, as they need a lot of current and that demands a low FET Rdson. It also demands good thermal performance, something that the small FET packages, like the TO220 size ones found in most controllers, can't provide.
Undoubtedly some of the big packages, like the SOT227 and the even bigger ones like the Ixys modules, are excellent at getting rid of heat from the FET junction, which mean they can handle a lot more current than their smaller brothers. The down side to big FETs is the need to provide more gate drive current, as gate total charge increases with the size of the FET. 2A should be enough to drive even big IGBTs, if anyone wanted to venture in the >100V realm for extra power.
Jeremy
