Simple PAS to throttle converter using an Arduino Nano
please help i conected all correctly and when i move the "imans" the motor runs but don't stop... and when i stop moving the "imans" the motor runs and stops again and again... red led flashes... i don't understand im desesperate :c i was 4 hours trying to fix it but nothing i can do, if somebody can help me please.
i have sabvoton 72150
look... https://youtu.be/GViW_z241y8
Big_Truck said:
Tiger_one said:
I am running Violamart hub motor with NO display or anyway to control PAS so I need this!
The Violamart controller can be connected to a SW900 display, allowing you to access the PAS settings. You need to connect 2 wires for the serial comms (Rx Tx) on the board and move the DMS connection as below.
I Used the existing 6 wire throttle cable, so I could use the throttle, as below.
In the controller:
Removed the green and yellow cables from DMS to - Green to Tx, Yellow to RX. Located at the far end of the board
Put a blue connected to DMS (where the Gr and Y cables were ) and brought out through grommet.
Using the cable to the throttle:
cut the Brown, Green and Yellow cables
cut the plug off the SW900 (mine was not the waterproof one)
connect (T)brown to (SW)Red
connect (T)green to (SW)Green
connect (T)Yellow to (SW)Yellow
connect extra blue cable to (SW)blue
joint (T)black to (SW)black - keeping the black connected out to the throttle.
worked straightaway fro me.
Newer SW900 has 9 PAS levels
Thanks for the detailed tutorial,
does this also somehow work on controllers without pas or display connection (like sabvoton 72150) or is it just for controllers with pas to expand the setting options ?
What is an "imans"?
WHen you say the motor runs, what exactly do you mean? Runs just a tiny bit? Runs at full speed? Something else?
Same thing for "runs and stops again and again"?
What red led is flashing, on which device? The PAS cadence sensor? The Nano? The controller? The battery? ???
All this device does is create a throttle signal from a cadence PAS sensor, primarly for controllers that have no PAS input but do have a throttle input, so a PAS sensor that simply makes pulses for pedal rotations can be used "as a throttle".
If you already have a throttle, you don't need this.
If you already have a PAS input on your controller, you don't need this.
That sounds like it would totally solve my problem with the missing pas input on my sabvoton controller without spending 200 € on a CA V3 ?
So it does quite the same thing that i tried to do with the arduino converter right ?
So i could connect this display to my sabvoton 72150 that has no pas input and then connect a pas to the display and the display signal output to my throttle input and use the pas additional to my throttle ??? That would be awesome
This *is* the arduino converter.
If you're talking about the SW900 display, that's just a display for specific compatible controllers (probably not including sabvoton, but you can check with the manufacturer if you can get them to answer you) and is not a PAS sensor, nor does it have any inputs for one.
Oh, maybe i misunderstood that. For me the post my question was based on sounded like a tutorial of how to use a sw900 as a pas to throttle converter (like the CA V3 does). But maybe that was too good to be true ;)
I'm afraid i should buy a CA V3 if i want a reliable way to use a pas.
I don't know if it is or not--I am not aware of how it could do that. I have some Kingmeter SW900 displays (with various brand name markings) and none of them have any connectors for stuff other than the power and datalines to/from the controller. Nothing for PAS or throttles; those all go directly to the controllers that go with these displays.
If the poster with the step-by-step has a different version of the LCD that does have these connectors and capabilities, hopefully they will post a link to where they got it. :)
Hello,
thanks a lot, i build the converter for the HIMO Z20 and it worked very well.
:bigthumb:
Unfortunately, the drive supports less and less depending on the battery level (in the end only up to ~ 15 km / h). But this is also so with the throttle.
Hi, good idea. It works, but every now and then I have short engine outages, about half a second. I tried changing the "activityTimeoutMS" parameter but it has no effect on the outages. Maybe if the 12 magnet PAS sensor is not faulty. Did anyone solve a similar problem?
Thanks a lot for sharing your tutorial fkopac.
I already soldered and connected many wires but have never worked with "Small stuff" like arduino or diodes or whatever your drawing shows :) That leads to my next problem.. i don't know how to read wiring diagrams and what parts are needed.
Would someone be so nice and write down a part list so also a newbie can find them on amazon or wherever ?
And could someone who already built the converter please share a picture of what the thing looks like when its ready ?
Thanks a lot for your help guys.
Best regards
Sparfuchs, vienna
Hello Sparfuchs, did you finally get the converter going ? If so can you please share the results, code and pictures. Thanks :)
Well if you could help me yourself i appreciate that so much I'm trying to adapt pas to a fardriver controller using Arduino but I'm totally lost
Have you tried the circuit and the code described in the first post?
