I'm working on a charging system for my 1993 City-EL which is powered by 14 ThunderSky LiFeYPO4, 100-AH batteries. I've bought most of the parts, and I've tested a rough prototype. So far it appears to work great, but I wanted to see if anyone has any comments or suggestions before I try to put it all together.
My new charging system is based on DC/DC converter modules, model VSX40MD23, currently ridiculously cheap on Ebay in lots of 24. I've been testing this module (with ORWH-SH-148D relay to disconnect the cell when there is no input power) and it seems to work GREAT as a charger. There is a "trim" feature which I can use to adjust the maximum voltage, and the output current appears to be limited to a tad under 14 amps. The efficiency of this module is rated at 89%, which is better than other similar devices I have seen.
This type of converter works great as an "emergency charger." If one cell is depleted, I can use my pack voltage to give that cell a boost and get back on the road. So, except for minor inconvenience, my range is no longer constrained by the "worst" cell. Yay!
I'd like to take it a step further, because my cells are prone to balance problems and my existing charging system is poor. I want to permanently mount a converter module on top of each cell to use as my primary charging system, perfectly top-balancing my cells every time I charge.
Top-balancing is ideal for my application. My vehicle seldom goes over 1C discharge, so my CellLogs configured at lower limit 2.8V give several miles warning before I have any problem. I'll have a switch mounted on each cell to activate "emergency charging" using pack voltage, as needed, with minimal fuss. Actually top-balancing gives me enough range that I don't expect any need to do that, but it's a nice feature to have available.
Ejonesss has reported that without protection, the cell voltage will damage the converter when its input power is disconnected, so the relay is important. I'm also adding a fuse, and a diode for relay back-EMF, and I've bought some small computer fans and N.O. temperature switches for cooling.
I expect to order custom circuit boards for this project, because my attempts to solder thick wires to my relays and converter modules have been clumsy at best. I've been working with ExpressPCB software to design the board. It's pretty easy to use and kind of fun, so I'm making progress. (Unfortunately ExpressPCB doesn't allow a hole large enough for the battery terminal bolt, but I guess a drill will work well enough.)
My power source will be the transformer from the vehicle's original charging system. It produces ~45-55 VAC, so I'll use a bridge diode to convert to DC. For "smoothing" I think I'll use a 33-microfarad, 0.5-ohm electrolytic capacitor mounted at each module as suggested in the Application Notes, and I figure it can't hurt to use an additional capacitor located at the bridge diode. I don't have experience with this, so any specific suggestions are appreciated.
Some more details and documentation:
VSX40MD23 Data Sheet
VSX40MD23 Application Notes
48V Relay Data Sheet (ORWH-SH-148D)
The VSX40MD23 Application Notes include a discussion about "conducted EMI" and some suggested circuits for dealing with it. So far I've ignored it because it looks complicated and I don't understand any of it. So, if anyone thinks I need to worry about "conducted EMI", please advise.
By the way, is there any consensus on the best maximum voltage to use, for a reasonably complete charge while optimizing the longevity of the cells? I'd like to be able to walk away and leave the charger on a trickle charge without damaging the cells. I think 3.5V will do a pretty good job, but suggestions are appreciated.
Thanks!
Thanks!
