Could I get some advice on this build?
I got a Sixthreezero EVRYjourney cruiser (7 speed variant) for the wife, and then I bought myself an e-bike and everything changed. Now I gotta electrify hers so she can come with me. I'm trying to keep it economical. Must go at least 20mph in real-world use. Must operate with throttle or pedal assist, preferrably thumb throttle.
Option 1: Bafang BBS02+battery
This one will work but it's $500 with no battery. The convenient thing is that I can keep the rims and the white-wall tires that give the bike it's nice look. I don't want to compromise the "cuteness" if you will, because the Mrs. really loves that about the bike. However, adding on a light kit, phone charger, and battery will bring the mod close to $1k.
Option 2: 48v 1000w hub motor kit
Universally available for $200 and easy to install. Slap on the battery and accessories and she's up and running for $600. However, the included rims appear to be a more common 35mm or so. This bike has some very narrow rims, only about 19mm wide. The tires are 26x1.95, ISO 47-559 (picture attached). What does one do about the rim brakes? Do I need to get wider calipers or can I just make the existing ones open wider? Would the original white-wall tire be able to fit on a wider rim or would it be no good? If I had to sacrifice the brown rim it wouldn't be as big of a deal as losing her white-walls. Lastly, these typically seem to be twist-throttles. Are twist-throttles reversible? She has a right-hand grip-shifter, so I'd have to put a twist throttle on the left side (images attached)
Option 3: Remove rim from 48v 1000w kit and put hub motor on existing rim.
Is this even doable?
In regards to batteries, do we trust no-name Chinese kits? Or do I only want to be buying battery packs with Samsung/LG/Panasonic?
