roadstar
Hi,
I’ve just bought 3 yuasa rec14-12 lead acid batteries as a stop gap measure until I can get li-ion.
My SLA charger when charging has a red led which goes green when the battery is fully charged (so the charger reads). I’ve been told I should leave the charger running for 8 hours even if the battery light goes green after its been on for a couple of hours (which is normally the case after a 5 mile ride). I just wondered if this was true?
My chargers a cheap 1.5 amp 36 volt charger.
The other question is how low can I allow the voltage to go during a ride without battery damage?
I rode for about 5 miles and checked the voltage and it had dropped from 39.5 volts down to 38 volts – the battery had not lost any of the indicator lights on the throttle.
Thanks in advance
Thanks in advance
