Conversion to AC just to convert back to DC at such powers is going to be impractical, to say the least.
I agree with you. And yet, depending on which model Tesla OP has, battery voltage could be 350-800vdc. So you're suggesting an 800-900vdc solar system, and an 800v buck converter, and a solar battery pack voltage of 900v. Once you start looking at the availability and cost of equipment in that price range, you may be rethinking your definition of 'practical.' Oh, dnd even if one were to decide to go that route, you would then need to hack your car's communication protocol to enable direct DC charging. Maybe it's easy, I personally haven't researched it, but I doubt Tesla makes it easy.
Let's say all that is overcome, and someone is fine with building a 900v home battery pack and hacking their Tesla to accept output from an 800v buck converter, so they can charge at 50kw. Big assumption, but okay. Even if that happens, you would be wanting 50kw of solar to replenish your battery! OP stated a goal of a 100kwh battery, which would be depleted in 2 hours at 50kw of charging. How long would it take to recharge that battery? 50kw of solar panels, assuming 400w panels... that's 125 panels. That's also assuming constant even sunlight on all of them...
Anyway, all I'm saying is while the idea is technically possible, and I would genuinely love to see someone do this, it's really not worth it: time, resources, space, equipment, money, just to shave a few hours off charging times.
