amund7
1 W
d8veh said:If all else fails, it's fairly easy to switch to an external controller. When I did it, the controller was blown, so I unsoldered the hall connector from it and soldered it on to the new one, otherwise you have to solder another one onto the motor hall wires, which can be done, but isn't quite as easy because of the shorter wires. You just take out the controller and it leaves the three phase wires with spade connectors and the halls with the block connector. Run your controller wires through and connect them in the compartment.
I see, and I know of the possibility for future mods.
But the fact is I paid a lot of money for this wheel, including the controller, I've only been running it for about a week, and the problem was there from the first moment. So I don't think it's fair if I have to invest time and money to get it working like it should have out of the box.
Dogman Dan, the motor gets warm-ish, the internals I can't say. But my previous test of parking the bike outside for 5 hours after using 2Ah, then resuming. Result: Motor pulled exactly 18A. So I'd say temperature is out of the question.
