SOLVED: Hall wire connector, wrong wiring, motor doesn't run
jai134
My motor did run for a few seconds at first, now it doesn't. I looked at the hall wires from the motor and the controller and they are mixed up. Yellow from the motor goes to blue from the controller, green to green and blue to yellow. Is that why the motor does not run?
I tried to do an angle identification and it started fine but stopped after just 30 seconds or so, beeping a code for wrong wiring . The code is for "Automatic error identification" and the error is "Wrong wiring of motor phase line or hall".
Why did it run at first if the wiring is wrong?
I can see that the throttle works when I use "monitor" in user program. No errors. Only problem is that the motor does not work.
I have a Kelly kls7215NDC and a BLDC 108 motor from golden motor
Tried an angle identification again this morning and all went well. I've been out for a 15km trip. I'm happy.
