kiltedcelt
I need to splice in an extension from a PAS sensor to my Cycle Analyst, and the wire from the sensor is four strands inside of unlabeled black housing. The wires are red, green, blue, and black. I can find some basic four conductor wire but everything has writing all over the housing. It probably doesn't make any difference because most of the run, the cadence sensor wire is going to be wrapped up in wire wrap with other wires/brake/shifter cables. However, aesthetics - some places the wire is going to be exposed and I'd prefer to just have a black insulation with no lettering. Also, I'm not 100% sure this is 22 gauge - might be 24 based on how tiny the wires are inside of the insulation. They look like phone or data wires in terms of size. I *could* just buy CA plug wire from Grin and cut off the CA plug and simply not use all of the wires, but that is kind of ridiculously expensive for what I need. So, any sources or suppliers for this kind of multi-conductor wiring? Thanks.
