grandmasterE said:
Sorry to burst your bubble, but a mongoose pro and a jamis dakar are each crap bikes. The Kona Dawg is a decent frame for its intended use. If you want to compare apples to apples, compare your team DH to a kona supreme operator which also weighs in the neighbourhood of 40-45 lbs, but uses a similar suspension design to the Dawg. I'm not surprised that you find a team DH frame to be stiffer than a XC frame. It should be, it weighs 50% more (the frame itself is probably 75% heavier).
I understand that you've ridden 4 different bikes and in some circles that might be an incredible number, but you are in no position to accurately judge if I am full of crap. You're comparing a QR rear end to a bolt-on through axle and then ascribing the extra stiffness to the suspension design. Good thinking. I'm not sure intelligent people would make the connection but you seem to have.
I don't even know where to begin with this other than to say I think you should keep an open mind. You never know where you might learn a lesson or two if you're receptive. Maybe spend 30 minutes at your LBC and double the number of different bikes you've ridden. Eight bikes as a grand total for your entire life will be a huge number I know, but just think how much you'll know then!
E
So, how many
E-BIKE converted duallys have you ridden?
And which was the stiffest frame for e-bike use out of my old bikes?
The Mongoose Pro. 7 Series ally, robust rear end. It was not super high end, but it's not the same as normal "Mongoose", which is K-mart rubbish.
The Jamis Dakar was not a crap bike - that's a $2000 bike, a beautiful ride before conversion. Sure, it was before hydros, but it was a well spec'd XC bike that rode really well. As I learned, dual suspension XC frames are not suitable for ebike conversions (well, maybe the lightweight friction drive).
The Dawg was stiffer, but not stiff enough, and not as stiff as the Mongoose. The Dawg is a heavy XC frame, but the pivots were not robust enough for me to feel confortable with a rear motor on that frame. A Stinky would be a bit better, and would be the bare minimum imo.
And the DH team (which is no longer through-hole rear axle - so that's irrelevant) is the best I've converted, rock solid. Ask Dr Bass http://endless-sphere.com/forums/viewtopic.php?f=3&t=18473
Also good is the cromo Avante D-Eight, with a similar suspension design.
This isn't about how many "normal" bikes anyone has ridden, it's about e-bikes, with unusual weights in unusual places, which have been tested to death (in two cases).
Ok, you're right, a Kona Operator will probably be fine, but I've need seen/heard of anyone converting one. A Kona Bass is good too, from reports of a friend with a BMC motor fitted and frame lipos.
It just seems easier to me to go with the design that is as close to a motorbike as practical, because let's face it, we are starting down that path. Keep it simple.
