betarambo
I found a guy who had modified his spoke machine so he could make shorter spokes for hub motor projects. Dave at http://www.dggreenproducts.comChalo said:betarambo said:I strung up my MP3 to a 14" motorcycle wheel. I think this might be the shortest spokes anyone has done on a hub motor. They are under 1" long.
Well done.
How did you get 1" spokes? The shortest anyone has been able to cut for me has been about 65mm.
Chalo
I wasn't sure how it was going to pan out so I asked him to cut the spokes to 1 1/8" and make the threaded portion twice as long as normal. This gave me some options as I messed with spoke patterns. I ended up changing from a 28 spoke wheel to a 32. (I am ashamed to say not for the increased strength but because I found a blue anodized one on ebay cheap and I wanted it pretty). Once the wheel was true I cut the excess spoke material and ground them smooth with a die grinder. Note that a nipple with a hex end was critical here as a spoke wrench would not fit in the gap and you can't get to the nipple anyway as bicycle nipples are too short to poke through the dimples in a motorcycle rim. (I know, this means I have to remove the tire if I want to tighten spokes, but I think that is livable) This problem might happen even on a bicycle because the Belleville washers take up some room. Also keep in mind that the washers make the nipple stick out more inside the wheel so you need to spend more time making sure they are smooth and you need a little extra rim band. I used three passes of electrical tape and then put a motorcycle rim band on. We will see how it holds up.
Spoke with washers and nipple as used:
Like Chalo said, the tensile strength is only defined by the diameter of the spoke. The short length should make them harder to bend but I don't expect that to have any real advantage since (as established on this thread) the strength of the wheel all comes from tension with conventional spokes.hjns said:Nice work.
However, it makes you wonder what the tensile strength is of such short spokes. But for the issue at hand, this was probably the easiest way forward.
Farfle, cool project. I am guessing that is a 16" motorcycle wheel? I had considered going with something like your design, but this is a bike for my kid and I plan to keep making it bigger as she gets bigger so being able to upgrade to bigger rims in the future is important to me.
